What flywheel
  • dusterbd13
    • Oct 2008
    • 102
    What flywheel
    04 Buick rendezvous la1
    99 camaro world class t5
    going in a 99 miata
    ive read that the 2.2 s10 flywheel is the one to get. But ive also read it needs shimming and such.
    wo, what clutch and flywheel should i be looking for?
  • sharkey
    • Jun 2004
    • 2061
    the 2.2l flywheel will work, its the same as the 2.8/3.1 fwd flywheel. the s10 clutch kit is likely your best bet, itll match the flywheel.
    digging on rock auto it looks like the 99 camaro 3.8l uses the same pressure plate bolt circle as the s10 2.2l, however the clutch is 9 11/16 instead of 9 1/8" for the 2.2l.
