93 Grand am 5 speed swap, INFO NEEDED FAST!
  • grandprixgtp_91
    • Nov 2003
    • 758
    ok heres the scenerio, i have a 93 grand am se, it has a 3300/ 3.3L v-6, and a turbo hydramatic 3t40 automatic, ive come to the conclusion that the transmission is Fucked (with a capital F ) and its already the second transmission, so i want to dump a 5 speed into it, so i found a 92 caviler z-24 with a 5 speed, can i use this in my car? i need to know right away though, because i need my car to get to work so i have to get it done right away. and what about the axles, will they fit in my car?any info is greatly appreciated. thanks
    Jake
  • korbendallas68
    • 3400swap.com •
    • 553
    If that Cavi is a 4-cyl then...
    In one word: No. Never. Nope.
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    • RidgeRunner
      • 971
      A 92 Z24 will have a 3.1L V6. I don't know about swapping it into a 3300 N-body though.
      60v6's original Jon M.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        3.1L's and 3300's ahve the same bolt pattern. As far as everything else goes I coldn't tell you.
        Swapping to a manual is not an easy task. Best bet is to just start stripping the donor car and seeing if the parts fit.
        • grandprixgtp_91
          • Nov 2003
          • 758
          well i didnt get the donor car, i bought all new clutches, steels,band, gaskets, seals, torque converter, pump and shaft, drive chain, and a tcc lockup switch. so im gonna overhaul my original tranny for the car, it all cost me $480 after taxes canadian.
          Jake
