i went to the tranny shop and asked him why does my car go crazy in over drive so i scanned my car and i got a po705 code a malfunction he said the this was a park nutral switch is he right and if do do i need the switch or the hole harness
park nutral switch
Tags: None
RE: park nutral switch
What year and model of car/engine/tranny?-Brad-
it is a 94 z34 with the 4t 60 e tranny
it did not do any thing please help. it is getting on my nerves
i made sure that everything was aligned and put it back in.could it be the the tcc solinoide. the park nutralswitch thati bought was for a 95z34 because the 94 was a split year and it had a removable connector.
scan tool reads the computer and gives you a real time read out of whats the sensor readings are.. Any good shop should have one.. This way you can check to make sure when you put the car in over drive, the computer should show that the car is in over drive.. you should run it through all the gears to make sure its all reading correctly..
