trans bellhousing patterns
  • patgizz
    The Plaid Bandit
    • 1071
    i know we had this discussion on the old board but thats gone now...
    i need to know if a 60* engine(3x00) will bolt up to and work with the 4t60-e in the 95 grand am i just got that has a quad 4. there's a 2001 3100 on egay local to me that would be a nice upgrade from the seized 2.3
  • BowtieKid79
    • 59
    all the 60*s and the 3.8s (and all 3.8 variants) use the same bell housing. the quad four and 2.4 Twin cam use a different bell housing that will not bolt up.
    • patgizz
      The Plaid Bandit
      • 1071
      damn, i was hoping a trans wouldnt be needed, because the motor is a screaming deal and only has 38k miles and is local.
      • patgizz
        The Plaid Bandit
        • 1071
        are the guts interchangable if i were to find a bad or high mile one from a v6 car?
        • v6h.o.
          • 1418
          yes they are interchangable. you'd need a V6 trans case.
          its the Starter location that is different on the 2.3L quads and 2.4L twin cams. they have the starter located at the top side of the trans.
          Colin
          • Rhedalert
            Dr. Feelgood
            • 1574
            I thought the Grand Am uses the 4T40E or 4T45E in those years?
            Brian
            3400 SFI V6, 4T60e
