Trans Go
  • jweir22
    • 111
    Trans Go
    Is there a shift kit for 4T60-E in a 95 3100? Couldn't find it.Somebody direct me.Thanks
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
  • Homer
    • Nov 2003
    • 79
    shimming your accumlators will do more for less money than a shift kit.
    -Homer
    • Rhedalert
      Dr. Feelgood
      • 1574
      I want to know more about shimming the accumulators. Basically this compresses the spring further, and makes the shifts firmer or quicker?? How much of an effect does this have as compared to using an adjustable vacuum modulator?
      Brian
      3400 SFI V6, 4T60e
      • 4spdz34
        • 185
        an adjustable modulator only firms the shifts at part throttle, it does nothing for wot shifts.
        • jweir22
          • 111
          How big of job is it to shim the accumulators and how big is the shim.
          Cold Air K&N Filter
          58mm TB
          • Anonymous
            I did 1/2" on each of my springs. Its basically: drop the pan, pull a few more bolts, then the accumulator assembly drops out. Pop in the washers, then re-install.
            • Rhedalert
              Dr. Feelgood
              • 1574
              Whoa...I must have been thinking of servos!
              Brian
              3400 SFI V6, 4T60e
              • jweir22
                • 111
                How many springs are ther to shim on a 94 4060tE.
                Cold Air K&N Filter
                58mm TB
