street clutch recomendations
  • sharkey
    • Jun 2004
    • 2061
    car is an 86 z24 cavalier, it has a getrag 5 speed 282 from a 90 z24. im soon going to be finnished building my 2.8l ironhead up and when i drop it in im going to put in a performance clutch. i have a couple in mind, but i want to know what everyone recomends.
    this is a daily driven car that will see street legal nights at the track. im aiming at over 200hp with the motor. being a daily driver, i dont want a puck clutch, and i need a sprung hub. i would also like to have a soft pedal (a bit more firm is ok, just dont want firewall bending, seat breaking stiff)
    i was thinking of a clutchmaster stage 2 or 3 (leaning towards the 3). i havent heard much about them, but they look like a nice clutch. i have heard mixed thoughts with the bully stage 2 (some work well, some smoke out running mid 14s). i havent heard much on the spec clutches either.
    so, what do you guys run??? what would you recomend???
  • Kohburn
    custom fab-whore
    • Apr 2005
    • 165
    personally i recomment the spec stage 2 kelvar clutch - rated for 340ftlb torque http://www.specclutch.com/specMain.html
    • sharkey
      • Jun 2004
      • 2061
      ttt
      • Doubt_Incarnate
        I still watch ROBOTECH!
        • Jan 2005
        • 1130
        i got one off the fiero store, should handle whatever a N/A motor can throw its way, its got a little bit bigger (1/2" i think) friction plate. but fo boost you'l probabyl want better.
        • spacecadetz26
          • Nov 2004
          • 119
          i have a spec stage 3 ceramic, if your not going to use nitrous or boost, go with the stage 2 kevlar.
          Stephanie
          92 GTZ ~SupermoddedW41GTZ~
          • sharkey
            • Jun 2004
            • 2061
            eventualy i will see nitrous or boost.....or both. im not to keen on a puck clutch, id rather go with a full ceramic disk. from what i figured out on my desktop dyno 2000 the most torque i would be getting with my light boost and nitrous would be just over 300ft/lb, so i think the stage 2 will work out fine
            • z24turbo93
              • 50
              umm i would not buy a spec stage 2 clutch. spec stage 3 doesn't even hold 6 psi on a 3.1. Get a bully clutch they are one of the best you can get for a 282.
              Spec needs to pull there head out of there ass. Stage 3 can't even hold 250 lbs torque
              • sharkey
                • Jun 2004
                • 2061
                well, so far all i can get localy is a centerforce dual friction. it was gonna be about $300 canadian with release bearing (they even have it in stock). im not big on the cf clutch though, id much rather have a bully or something. the place id be getting it from (mopac auto supply) is one of the big distributors of performance parts to the parts stores, so unless i order in, im not sure what ill be getting.
                i guess ill have to order a clutch from stateside and hope i get it quickly
                • spacecadetz26
                  • Nov 2004
                  • 119
                  centerforce DF wears very quickly.
                  Stephanie
                  • sharkey
                    • Jun 2004
                    • 2061
                    thats what ive heard. i also know they dont have the weights on the pressure plate, so you basicly get a good disk and a slightly better pressure plate.
                    • Z2_4cams
                      • 147
                      go Bully. you WON'T be disappointed.
                      1989 Z24 3.1/3400 hybrid
                      14.13@96.69 N/a slick full interior
                      maybe my \"dreams\" should be a little higher :P
                      • geoffinbc
                        Iron Head Enthusiast
                        • 5831
                        I have to agree. I installed one with my buddy in his Z24. That is a premium clutch. The 4 puck design offers superior cooling aswell.
                        • sharkey
                          • Jun 2004
                          • 2061
                          im not willing to go with a puck clutch. the car will still be daily driven and i need a clutch that isnt stupid in trafic.
                          ill have another look at the bully stage 2.
                          • RacerX11
                            • 1060
                            The marcel in the clutch disc has more effect on how abrupt it engages then pucks vs no pucks. More clutch companies are combining the holding power of the 4 and 6 puck clutches with the sprung hubs and less aggressive marcel material to make a strong street clutch. Try a 6-puck clutch dics from www.clutchnet.com There are some Fiero guys running these on the street with success. I plan to go with the 6-puck, sprung-hub model in my car, which will see street action.
                            Marty
                            '99 Z-28 - Weekend Driver
                            '84 X-11 - Time and Money Pit
                            Quote of the week:
                            Originally posted by Aaron
                            • geoffinbc
                              • 5831
                              Buddy that is a bully stage 2 clutch Pucks or no pucks do not affect the ability to drive on the street.
