I'm dazed and confused on 60 deg manual trans flywheels.
I understand that there are different flywheels for the earlier external balance 2.8L engines , and later neutral balance flywheels for the later 2.8 and 3.1. etc engines. That I understand, but after that I am confused.
I've never seen the flywheels for either a FWD or a RWD 60 deg V6 in person. Are they the same diameter? Same thickness? Any quick way to tell if a 60 deg manual trans flywheel is for a FWD or a RWD??
I thought that all the external balance RWD flywheels would be the same, but Advance Auto Parts shows a different p/n for the external balance Camaro flywheel compared to that for an external balance S-10 wheel. Is there really a difference or is Advanced data base jacked?
When I get into FWD manual trans flywheels I'm more confused. The Advanced Auto parts data base shows the same flywheel (casting number 14018712) used for two different FWD (Cavalier) applications; both a internal balance 2.8L V6 with a 9-1/8" clutch, and a 2.2L four cylinder with an 8-1/2" clutch. Again, seems odd. If true, is the flywheel drilled for two different pressure plates, or do the two different pressure plates have the same bolt pattern??
Thanks for any help
Piper106
Thanks for any help
Piper106
