solved why tranny felt like it was stuck in park
  • michigander2005
    • Aug 2005
    • 11
    I have a strange problem ,, shifter is on column and moves in all positions ,, but tranny feels like its in park..
    removed right side axle to push car in garage
    Rebuild on weekend ... call junk yard Monday come and get er.
  • RacerX11
    • 1060
    RE: tranny feels like its stuck in park
    Might be the shift cable. Look at the trasmisison where the shifter cable attaches, and have someone move the column shifter to see if the linkage is moving or not. If you are lucky, maybe it just came unbolted.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
    • michigander2005
      • Aug 2005
      • 11
      Re: RE: tranny feels like its stuck in park
      Marty
      wish it was the cable but not ,,I'm thinking of buying atsg book to see how hard it looks to rebuild i already have the tranny pulled sitting on garage floor.
      • CurtsLuminaZ34
        • May 2004
        • 25
        Before you go tearing into the trans, flip it over, remove the pan and see if the shift mechanism (rod that engages the parking pawl) is stuck worn out or broken. You might be able to repair this instead of overhaul.
        Curt
        \"Experimentation\" the mark of a verteran weekend garage warrior
        • michigander2005
          • Aug 2005
          • 11
          Prior to its not moving forwards or backwards we did have clicking in reverse ,, pan removal shows the new fluid full of metal powder like junk.
          • CurtsLuminaZ34
            • May 2004
            • 25
            Most likely the plantary gear set is failed, sorry to hear it's gone out
            hope to hear it's fixed and back in soon! Curt
            • michigander2005
              • Aug 2005
              • 11
              I Don?t have the book yet ,, question any idea if its safe to remove diff cover nose for inspection of gears or would I be looking for a disaster ?
              Thanks in advance
              • CurtsLuminaZ34
                • May 2004
                • 25
                It would be okay to remove the cover and check the final drive planet set, but I was refering to the main plantary gear set deeper inside. Curt
                • michigander2005
                  • Aug 2005
                  • 11
                  Thanks for the reply,, this am I've taken the plunge and going in deep into case using 4t65e alldata
                  Houston
                  • michigander2005
                    • Aug 2005
                    • 11
                    Here is why it felt stuck in park.
                    gotta find a place to buy one
                    parking lock actuator assembly
