Driveline loss 4T60E vs. 284
  • Kevwood
    • May 2004
    • 122
    Okay guys, I forgot to post these results. For a long time there has been a lot of speculation as to what the drivetrain losses of the 4T60E and Getrag 284 are. I have these numbers for you;
    Engine in my red car with the 4T60E -> 225 WHP
    Engine in my white car with 284 -> 240 WHP (before additional tunning and u/d pulley)
    This was taken out of the red car and dropped right into the white car, NO CHANGES WHATSOEVER.
    So, 15 WHP difference. I was told by a few GM tech's, two different tranny rebuilders and a tuner of these w-body cars that the 4T60E has a drivetrain loss of about 25% & the Getrag 284 has a loss of about 18%. Michael at FFP also uses the 18% loss to calculate his WHP (265 - 18% = 217.3 or 218 WHP) I believe these numbers to be true, look at this;
    240-225=15 OR 225/240=93%, a 7% difference.
    25% 4T60E loss - 18% 284 loss = 7% difference.
    So, there is no question that there is 7% difference between the transmissions. One 'mystery' down, lot's to go...
    P.S. The FFP pulley was exactly 5 WHP, virtually no difference in voltage and no difference in operating temp! Great bang for the buck!
    Z34 red, auto, written of by a red light runner.
    Z34 white, 5 speed, stored in Canada
    Mercedes-Benz C20K, Dubai
    Mercedes-Benz CLK500 AMG, Dubai
  • OldSkoolGP
    That guy over there
    • 930
    That's about what I figured for a 284. However, I have found one issue with the UD pulley. I have a 160 amp alternator. I don't know if that makes a difference, but if my lights are all on and the cooling fans are both running, my alternator can't keep up. If I have it wound out to 1200-1300 RPMs, it's running at full capacity again. And since Ben retuned my chip and the fans are always on in city driving, this gets to be a bit of a problem at night. Hopefully some creative electrical rerouting to reduce losses will keep this from happening.
    • RacerX11
      • 1060
      Most hi-output alternators trade low-rpm charging capcity for the higher current rating when spun faster. It sounds like your alternator and the UD pulley are not a good match.
      Marty
      '99 Z-28 - Weekend Driver
      '84 X-11 - Time and Money Pit
      Quote of the week:
      Originally posted by Aaron
      • timg
        • Feb 2004
        • 718
        I was calculating 21-22% (44 hp) loss for the 4T60e tranny. Here were my calcs.
        205 hp - 161 whp - 44 hp delta - 21.5%
        210 hp - 166 whp - 44 hp delta - 21%
        Tim
        325 whp 350 lb-ft
        • Kevwood
          • May 2004
          • 122
          Marty
          I agree, I had a high output alternator in my red Z34 to run all my audio gear - it sucked ass at an idle, 1,200rpm it was fine. I chose not to run that alternator in this car, the stock one is just fine with an Optima battery to run all my electronic goodies on the way.
