Teflon rings on imput clutch housing sizing
  • michigander2005
    • Aug 2005
    • 11
    Rebuilding a 4T60E book shows using special tools for Teflon oil rings installation and for sizing..
    big problem if they go back in tranny as out of package or should I borrow beg or buy the tools ?
    Rebuild on weekend ... call junk yard Monday come and get er.
  • TurboGTU
    • 453
    RE: Teflon rings on imput clutch housing sizing
    IM a cheap ass and used aluminum sheets out of a soda can and a hose clamp to compress the seals and to install them. Kinda like a piston ring compressor/installer.
    I'd rent the tool or go the the trans shop and see if they do it for you since your not as "crazy" as I am.
    • michigander2005
      • Aug 2005
      • 11
      Re: RE: Teflon rings on imput clutch housing sizing
      Thanks for the hose clamp idea ,, appears to work
      currently stuck installing driven sprocket support part 609 in book ,, lacks 1/2 " of going on very very very tight fit
      • TurboGTU
        • 453
        RE: Re: RE: Teflon rings on imput clutch housing sizing
        Did you mesure the packs before? Did yo aligh them when putting on the sprag and sunshell?
        • michigander2005
          • Aug 2005
          • 11
          I'm sure clutch pacs are seated correct ,, I'm binding @ top of case side to side issue
