4t60e trans problems
  • tony94gtp
    • Jan 2005
    • 34
    first i have 2 codes in the ecm a 705 code which is the prndl switch and the other is 740 code which is the tcc switch. now this is what i notice when driving the car. when up around between 50- 60 mph and holding steady i notice the trans down shift down to 3rd gear rpms goes up to 3000rpm and it only seems to do it when its hot outside. now what i was wondering is if the prndl switch interacts with the tcc switch like if the prndl switch is shorting out and causeing the tcc switch to kick out? also can the home mechanic change the tcc switch themself . any suggestion would be helpful. the transonly has about 57000 on it reman from dealer ship. out of warrenty now. i havent done any fluid and filter changes thinking that i need to do that i read somewhere that the tranny will go into safe mode when it get hot
