5 speed swap wiring question
  • 93GTP
    • 125
    Does anyone know if there's a write up for wiring in the Clutch Start Switch and Clutch Position Switch (Shift Anticipate Switch)? I have everything I need out of my donor car now but I'm wondering what underdash wiring I may need to pull from the Z34 for my GTP.
    Does the auto harness have the wiring needed for these two switches? I'm guessing not, that would be too easy.
  • SHOoff
    • Jul 2005
    • 356
    I dunno about a writeup on the swap.. But I think there is one around somewheres.
    Anyways... about the clutch start switch. I'd assume that you'd wire it into where the Park/Neutral safety start switch was.
    97 Cavalier RS
    3400, Isuzu MK7
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      i just got a car that has a 5 spd swapped in it. the guy doesn't have one. i can crank the car without pushing in the clutch, which isn't a problem for me.
      have you wired up the reverse lights? this car does not have that wired either. i may end up doing a toggle if nothing else.
      • 93GTP
        • 125
        Well I'm just a bit picky when it comes to stuff like this. I want my car to be as close to an original 5 speed as I can make it. And there's a write up on this site for getting your reverse lights working right. Just look under the HM-284 under the transmissions section.
