Official difference between 4T60 and "-HD"
  • z284pwr
    • 88
    As we are researching for more info on rebuilding the transmission in our TGP, we were looking for possible rebuildable transmissions. Anyways, would anyone know the "official/actual" differences between the regular 4T60 and the 4T60-HD that came in the TGPs. Would they be differences in just the bands/steels/clutchs, or would it bei nthe actually gears and other parts? Question being because we were considering getting just a regular one and rebuilding it while we have the other one still in the car, then this question came up. Would we lose anything using a regular one with the new rebuild kit over the HD, or does this other, "HD," trans have the parts we would want?
    Brian Edwards
    '73 Trans-Am
    '79 Suburban
    '90 Beretta INDY
    '90 Turbo Grand Prix
    '04 TSX
    '04 TL
  • dbtk2
    • Feb 2004
    • 349
    I know you wouldn't want to use a regular valve body in it....I don't know all the differences in the tranny though, but the valve body is definately one.
    Shawn
    99 Grand Prix GT
    • sharkey
      • Jun 2004
      • 2061
      never seen a 4t60-hd, so i dont know whats different in them. im guessing its a different diff, probly stronger planets, more frictions in the clutchpacks.
      id rebuild the unit in your car. if you beat on it, id find out about some red eagle frictions. they have a lot better holding power. another thing to look into is a shift kit.
      • SHOoff
        • Jul 2005
        • 356
        Not sure. But I bet it's probably about the same as the difference between the 4t65E and the 4t65E-HD is. I know there's a few things, but not a whole lot.
        97 Cavalier RS
        3400, Isuzu MK7
        • z284pwr
          • 88
          Here is what has been scrounged up...
          Our valve bodies are stamped with "turbo."
          "Converter is different, stall speed. Valve body is different. The calibrations for the shift firmness and speed are all different. There are a few other things but as far as functionality those are the important ones. Any other 4t60 will bolt up and move the car, but its a crap shoot at how long it will last and how well it will function. I know a Turbo4t60 will act weird if the car is not making boost, and I know that a non Turbo4t60 can SEEM to work ok, but not last very long on a turbo motor. But that is just my experience. Since they have a turbo specific trans, I would say that it wouldn't work. But if you can get one cheap and build it for a turbo car, I would say it would work."
          (difference between shifting on normal 4T60 vs. turbo 4T60)
          "Its hard to explain. But there is a difference. The modulation on the TGP trans is alot more progressive, since the car can build boost. IE, TV pressure VS line pressure seems to have an effect on the shift quality more in the TGP, it will be much harder than on an NA car with more TV pressure. This could be why NA 4t60's burn out faster on a TGP, the clutches probably slip more between shifts at the same throttle positions, since they are not being applied as firmly. Other than that the shift points may be differnt, but I never compared them that closely. The biggest thing I noticed was shift modulation."
          We are definitely looking at stronger frictions. The thing I have noticed, all the shift kit things aren't for "performance" They just says not a performance kit. Most of the stuff we have found is from http://www.bulkpart.com they appear to have everything we will need. Hopefully we can find something for the performance thing so it will shift harder
          Brian Edwards
          '73 Trans-Am
          '79 Suburban
          '90 Beretta INDY
          '04 TSX
          '04 TL
          • torq455
            If I only had money!!!
            • 1615
            go with kevlar clutches. that'll firm up your shifts..
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
