92-98 L/N manual trans mounts
  • Erich
    masterbater mechanic
    • 67
    Frame/Chassis cut off from a 1992 Achieva SC Q4 5spd. Same as 92-93 V6 5spd and 92-96 2.2 5spd and 92-98 Q4 2.3/TC 2.4 5spd. The rear is same as a 89-91 Q4 5spd.
    These mounts can be used on Pre 94 J bodies. Free's up space on top for turbo and other intake enahncements. I do not know why GM didn't sell just these 2 pieces.
    1990 6000 SE AWD 3.1 "The Goose"
    1995 Beretta Z26
    1996 Beretta Z25 w/3500
    1999 GAGT
  • sharkey
    • Jun 2004
    • 2061
    the engine bay of the j/l/n cars is very simular. the mounts can be welded in, aswell as the frame sections will bolt right in. a buddy of mine had a ho quad 4 in his 90 z24. just welded the tranny mounts in and bolted the subframes in, and the motor will bolt in.
    • Erich
      • 67
      pre 1992 the Quad 4 bolted in using the rear mount and for trans it used the same as the rear(left bracket in photo) The frame used a crossmember. I also have a theory on that crossmember. The front goofy mount may not be the most desireable for mounting a quad but it sure does stiffen the lower portion of the car.
      1995 Beretta Z26
      1999 GAGT
