4T60 Transmission Problem
  • JohnJohnson3334
    • Mar 2006
    • 1
    I just put in a new transmission & motor in my 1994 Olds Cutlass Convertible. I only have manual shift, 2nd. & 3rd. No first & No overdrive. Speedo does not work...RPMS at idle are higher than they should be...Can anyone HELP....."Going Crazy"
    Thank You
    John
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Hey John! Welcome!
    From what you told me today, I suggest, as a start, to put back the stock chip. See if that helps. 94 and 95 are unique.
    sharkey is the tranny guy though.
    • sharkey
      • Jun 2004
      • 2061
      you will actualy have a 4t60e, big difference.
      get your speedo working, this is likley the problem. it sounds like the car is in limp mode. the ecm needs to know how fast the car is going to determine when to shift. if it has no speed signal, it cant figure it out, so the ecm puts it in limp mode, 2nd gear.
      there could be other issues, but resolve that first.
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        VSS, right?
        • sharkey
          • Jun 2004
          • 2061
          yup
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            Old Dogs can learn. He also installed a Hypertech in a 94. Shouldn't work. Am I right again? Unless it is Bens.
            • sharkey
              • Jun 2004
              • 2061
              um, i couldnt tell ya, im the transmission guy, not the obd1.5 guy
              take the chip out and try it first.
              • torq455
                If I only had money!!!
                • 1615
                ummm, what's this OBD 1.5?
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                • patgizz
                  The Plaid Bandit
                  • 1071
                  the couple year only bastard engine management system between OBD1 and OBD2.
                  • sharkey
                    • Jun 2004
                    • 2061
                    its basicly an obd2 diagnostic plug and an obd2 style chip and pcm, but its obd1 programing.
                    • torq455
                      • 1615
                      sweet! i don't have it!! :P
                      Andy
