quad 4 tranny questions
  • sharkey
    • Jun 2004
    • 2061
    i know its not 60 degree, but its related.
    anyone here know much about quad 4s??? im looking for a 92-94 5 speed. did the LO quad 4 come with the getrag or isuzu??? from some other reading ive done, all 92-94 quad 4 came with a 3.94fdr, but there was a 3.94 fdr in the isuzu. i know the quad ohc (the sohc version) had an isuzu, but im not sure on the LO version. i know all the HO are getrags.
    im just wondering if i need to find a car with a HO to get the tranny from. quad 4;s are kinda scarce around my area, so i may have to do some calling around to find out who has what, and i need to know what im talking about.
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    what about the late model LD9 (2.4) from the new z24's? maybe that has the gearing you need
    • Doubt_Incarnate
      • Jan 2005
      • 1130
      not exactly what your looking for, here is a ton of gear ratios
      • sharkey
        • Jun 2004
        • 2061
        the 2.4l uses an isuzu. they are not a very strong tranny. they will hold some horsepower, but dont try to throw v6 torque at em.
        • FastGT31
          • Jan 2004
          • 146
          i may be wrong, but arent the only quads that came with the 3.94fdr are the ones with the w41 option?
          • sharkey
            • Jun 2004
            • 2061
            a couple people have pointed that out, but according to the getrag 282 section on this site and the quad 4 forums, the 92-94 quad 4 getrag has a 3.94 fdr, and the rpo code for that tranny is 3xtx. the w41 tranny has an rpo code 4xtx
            • MidnightriderZ24
              • Jan 2005
              • 699
              what are your goals is what u need to keep in mind. a 92-94 q4 ho tranny will be a shorter 4th only. it will limit u in the 1/4 for future plans. i chose a 90 q4 ho tranny. it has a slightly shorter 2nd, and the desired 4th, and 5th, that will help u if u plan to be boosted (like i am since i will be hitting 5th in the 1/4....i believe that its a 3.61 ratio and is a little bit more common than a 3.94fdr. whatever u do stay away from a 91' tranny
              [SIGPIC]
              12.268@117... 11's to come!
