3.4 dohc auto to manual 282
  • oxidenx
    • May 2006
    • 12
    I want put a manual tranny on my 92 z34 .. and it hard too find a HM-284...I want put a HM-282 with good ratio... I dont know if it will be fit and I dont know if I can put a quad 4 tranny or if its nessessairy to put a v6 tranny... can you help me?
  • sharkey
    • Jun 2004
    • 2061
    quad 4 tranny is a different bellhousing, it will not work.
    what you are going to need to find is a 282 from a 3.1l is a w-body. the way the trans mounts in the w-body is different from smaller gm fwd cars. aside from that, you need the pedal assmembly from a w-body as well as the console and axles, and anything else (clutch, flywheel, shifter cables ect) can come from any gm fwd with a getrag 282.
    • oxidenx
      • May 2006
      • 12
      oki ... tanks .... but can y put a manuelle tranny from a J-body...like a sunbird 3.1??and it is hard to fit the trans mount???because I dont know whats w-body have a manual tranny
      • sharkey
        • Jun 2004
        • 2061
        im not sure what you would do for mounts. i beleive the w-body has the mounts on the side of the case and they go to the subframe. i know the j-doy uses a top mount that goes to the unibody, and they dont have the mount bosses on the case.
        • oxidenx
          • May 2006
          • 12
          oki.... sorry for my text because I dont speak english very weel.... I'm from québec(canada) lol but my previous question ask about what king of W-body Have manual tranny....to know what I have to ask about to the scrap yard...I dont know if you see what i mind ,but thats all I can you explain!!!
          • TurboSedan
            • Jun 2004
            • 218
            '88-'90 Grand Prix or Cutlass Supreme has the Getrag 282 5-speed. you could probably have a W-body Getrag 282 rebuilt using gears from an L/J/N-body 282 but you definately need to use a W-body 282 case in your Z34 as others have mentioned.
            '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
            '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
            GM W-body Forums
            • oxidenx
              • May 2006
              • 12
              tanks.... I will get my new z34 soon...saturday after i will look for a manual tranny!!!!
