6 speed conversion
  • napatiger
    • 490
    6 speed conversion
    Is anybody working on putting the new GM/Ford FWD 6 speed onto our engines? That would be awesome.
    95 MC Z34 Black
    The manual from the G6? Or are you talking about the gm/ford 6speed automatic (is that even out yet)?
    I think a few people have talked about the G6 manual 6spd. I think one or two people are giogn to try. I believe V8 archie has made a few fieros with that trans too now.
    The 6spd auto, I don't know. It's probably really heavy.
      • 9191
        • 9191
        And I forgot to mention, the 4T45-E weighs 85.1kg, so the new 6-spd auto is 19kg heavier.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Man that first gear and the gap to second pisses me off. It should be in the 3.9 range. Why the hell is it 4.48 you dont ned that steep of a first gear
          • napatiger
            • 490
            i was thinking of the manual
            95 MC Z34 Black
            • sharkey
              • Jun 2004
              • 2061
              ford doesnt use the gm 6 speed. being you said gm/ford 6 speed, we asumed the new 6t75, its built and used jointly between ford and gm.
              • jb1
                • Jul 2005
                • 14
                They offer a 6 speed that works on the 3800sc so should be no problem for others.. They use to list alot of info about it on their site but could not find much on it now. @ the bottom it gives a break down of ratios on the 6sp.
                87 fiero gt
                3800sc/4t60e
                1/8th Et 7.597
                60ft 1.579
                mph 88.53
                • sharkey
                  • Jun 2004
                  • 2061
                  if i remember right, that is actualy a honda transaxle, im gonna guess from an rsx wit hthe k20 motor (200hp 2.0l). now i know its longer and mounts could be an issue in anything but a fiero.
                  as for the gm 6 speed from the 3900, i beleive they changed the bolt pattern, so an adaptor would be needed. im sure it could be made to work.
                    Hmm so that means a 3900 won't bolt up to older transmissions either? Jospeh Upson is going to use a 3900 in his fiero now....
                    • timg
                      • Feb 2004
                      • 718
                      They're actually NSX transmissions.
                      Tim
                      325 whp 350 lb-ft
