Transmission load problems
  • t3hchad
    • Jan 2005
    • 9
    96 Grand prix, SE, 3100 SFI, 4T60-e
    Well I think its transmission problems... the Valvebody solenoids on my tranny are making a humming noise... ill unplug the main harness going to the tranny and the noise goes away... plug it back in and it come back... is it supposed to make noise?
    also when the car is on extreme load it drops rpms down alot and struggles to drive till the load is gone or you tap on the gas and step on it hard... only does this every once inawhile...
    I think its tranny related... b/c all the vaccuum lines are good and every sensor on the engine is new... what could this be?
    *1988 GMC S15 sierra pickup, 2.5L "Iron Duke" I4, 25-30mpg
    *1997 Mitsubishi Eclipse RS, 2.0L "420a" I4, 30-36mpg
    *1997 Bayliner 1750 capri, 3.0L "mercruiser" I4 inboard/outboard
    *1999 Go-ped Sport, 1.2hp "G23LH" I1, 25mpl (100mpg),
    (soon to be a 5hp G23LH/CY29RC hybrid), Autolite 255, Walbro carb,
    25:1 Castro full sythetic oil, 93 octane
  • MMGT1
    MMGT1
    • Aug 2006
    • 104
    sounds to me like the car is pushing too much line pressure. Just a guess though, you should get this one onto a dealer dyno(Bear) before this one costs you some big bucks!
    Paul
    • t3hchad
      • Jan 2005
      • 9
      when it does this... feels the same as shifting up a gear and trying to drive in to high of a gear...
      • MMGT1
        MMGT1
        • Aug 2006
        • 104
        .....you may have a fused gear, so many thing can go wrong with the auto's. Guessing at it won't help you, I think you need to get this one in for service.....
        • t3hchad
          • Jan 2005
          • 9
          im throwing around the idea... of just converting to a manual... would help with alot of diagnostics... less parts to go through...
          • MMGT1
            MMGT1
            • Aug 2006
            • 104
            Manual is a big job man. Big one most people don't realize is the tuning that goes with getting a manual in there.
            • t3hchad
              • Jan 2005
              • 9
              so far from what i have researched... its not to hard... just have to make sure i connect the right wires to the write parts... which i already went through a bunch of wiring schematics... and drew me up a new one to go by... so i know which wires splice into what...
