Transmission fluid change on 02 GA GT
  • AznGA
    • Oct 2004
    • 32
    My 02 Grand Am GT got a trasmission flush done at 60k miles. It's at 100k right now. Do you guys suggest getting another flush or just a pan drop this time?
    My transmission sometimes hunts for a gear, meaning that the RPM jumps up and down at shift points and when I give it some more gas, it finally shifts. I heard that this can be related to the comtaminated tranny fluid? This issue dissappeard after the first flush, but it recently came back.
    2002 Grand Am GT
  • sharkey
    • Jun 2004
    • 2061
    i would always recomend a pan drop service. the shop i work for will do a pan drop service and then do a flush. the main reason for dropping the pan is to change the filter and inspect the pan for clutch material or metal. it is recomended that you change the filter with every service. i mean, you wouldnt change your engine oil without changing the filter would you???
    with electronic controlled transmissions, shifting is all controlled by the pcm, so i would be looking at a pcm input, like the tps.
    • tractorman
      • 451
      I always put a drain plug in the tranny pan the first time I do an oil/filter change. Makes life A LOT easier.
      What do ya'll think about that new Dexron VI? I'm thinking about putting it in both my cars next time I change the tranny oil.
      • prophiseer
        Blaspheming Heretic
        • Jun 2006
        • 354
        as for the DexVI - if you can find it, let me know! The dealerships 'round here don't even have access to it (including caddi).
        I'm with sharkey on the pan drop, etc. Actually, all you should need is a new filter and fluid. If you religously change the filter and fluid about every 30k miles, a flush is usually never needed. As for fluid, my personal recommendation is Castrol DexIII - I've never had problems with this brand and have yet to burn their tranny fluid in 30k miles (as compared to Valvoline which I was able to toast). I'd also recommend installing a bottle of ProLong tranny additive, it's well worth the cost and really works per their claims.
        On the GAGT trannies, there's a few TSB's floating around about gear slippage, rpm flutter, tranny fluid press, etc. If you didn't have a lot of crap removed in the flush, or a ton of shrapnel in the filter, you might want to investigate some TSB's.
        N-body enthusiast:
        {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
        {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
        Current Project:
        {'90 Chevrolet C1500 Sport 350TBI}
        • sharkey
          • Jun 2004
          • 2061
          dextron VI is a replacment fluid for dextron III. it is an improved fluid and was designed specificly for the new gm 6 speeds (hence jumping from dex 3 to 6). dex 6 will eventualy replace dex 3 altogether.
          • AznGA
            • Oct 2004
            • 32
            Yea, our trannys have some issue with the shift solinoid. But at this point, especially when I put 100k miles on this tranny, I don't think it's worth taking the tranny apart to replace the solinoid. I might as well get a whole used tranny from the junkyard. Besides the tranny hunting for a gear, the shifts are still crisp during WOT.
            2002 Grand Am GT
            • sharkey
              • Jun 2004
              • 2061
              putting a used tranny is it is the same as what you have now. it may be worse, or a bit better, but in the end those problems will come back to you again because you have another factory spec tranny without the updates that fix these known problems.
              • sprucegagt
                Old School KI
                • May 2005
                • 703
                Not unless he uses a transmission from a newer GA GT that has those updates already in it. Say like 04. It is a direct bolt in.
                Your local OBDII moderator
                2000 Grand Am GT w/ WOT parts
                • prophiseer
                  Blaspheming Heretic
                  • Jun 2006
                  • 354
                  true, but really hard to find in the scrapyard.
                  So, then, anyone know where DexVI is available? Around here it's non-existant.
                  N-body enthusiast:
                  Current Project:
                  • tractorman
                    • 451
                    It can't be THAT hard to find. The local chevy dealer out here in BFE Kansas has it. I haven't yet convinced myself to pay $6 a quart... maybe that's why they call it dexron $VI$.
                    • sprucegagt
                      Old School KI
                      • May 2005
                      • 703
                      Not really. You can get them for a decent price with low miles. Search of an 04 Grand AM GT with 3.29 FDR generated for 4 pages of scrapyards ready to sell.
                      • prophiseer
                        Blaspheming Heretic
                        • Jun 2006
                        • 354
                        I guess you could do it that way. I meant if you actually go out to the yards looking, which is what I'd prefer to do. Around here, not all our srapyards can tell ya what vehicle a motor or tranny they'll send ya came out of (lazy bastards).
                        N-body enthusiast:
                        Current Project:
