Transmission Shift problem
  • john_V63400
    Banned
    • Feb 2006
    • 409
    I have a 01 GA GT S/C V9 vortech blower and so on........
    My tranny is stock and has 34,000 miles on it.
    I recently started having shifting problems at full throttle shifts.
    It shifts fine below 3500 RPMs, but it sits at 4000 RPMs and just doesnt pull after that, and I also loose all accelleration.
    I accerlerate full throttle, as soon as it starts to pull to 4000 RPMs it looses all accell power, its like it's slipping and the engine still revs steady at only 4000, but nothing happens, almost like I have thrown it into nuetral and kept the Gas at the same RPM as if it was still in drive.
    What do you guys think, anybody have this same problem, Its an auto trans
  • 3.1POWER
    • 52
    If it was just trans slippage, your rpms would still increase..... interesting problem you've got here....
    • 3.1POWER
      • 52
      One of my friends thinks it may be a timing issue..???
        • 9190
        Neutral saftely switch. If the PCM thinks your car is in N or P, it will not let the engine rev past ~4k.
        • tijuana_no
          • Aug 2005
          • 261
          but,this could be fix with ben's chip.right!!!!!!
          i just love to watch the wheels turn around and around
          • prophiseer
            Blaspheming Heretic
            • Jun 2006
            • 354
            I was also thinking the manual range valve assembly might be starting to go bad.
            Outta curiosity, is it every gear it won't shift, or just certain shifts (i.e. 1-2,3-4)?
            N-body enthusiast:
            {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
            {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
            Current Project:
            {'90 Chevrolet C1500 Sport 350TBI}
