swap question??
  • TooManyCars
    • Dec 2004
    • 24
    swap question??
    Will a 5 spd manual tranny off a 2.5ltr chev bolt up to a 3.1ltr.. I just bought an 87 chevy s10. it has the 2.5 lt with the 5 speed and needs a new clutch.. well i have a turbo 3.1 ltr outa a junk tgp that I would like to swap in.. I could just do the 350 swap but thats just tooo common. so could it work???
    thanks Jim
    91 cavaliver z24 5 spd,
    89&90 TGP auto
    90 olds toronado trofeo auto,
    86 GLX RX7 5 spd,
    85 nissan 300zx 5spd,
    84 dodge ram,
    http://www.kustomdreamzcc.zoomshare.com/
  • Piper106
    • 25
    As far as I know the 3.4L will bolt up, as long as you use a bell housing, pressure plate, clutch disc, etc, from a 1980s 2.8L V6 S-10. Careful on the flywheel. The 3.4 is internal balance and takes a neutral balance flywheel. Early 2.8L engines were external balance, and had a balance weight on the flywheel. Later 2.8L engines were internal balance, you need flywheel from a an 89 and later S-10 to work with a 3.4L.
    That is all I think I know.
    Piper106
    • sharkey
      • Jun 2004
      • 2061
      did you copy and paste that from somewere??? he is talking about going from a 2.5l duke to a 3.1l fwd.
      the 2.5l bellhousing will actualy bolt right up to the 3.1l. you will need a 2.8l neutral balanced flywheel (88+) from a truck. also you will need the v6 clutch.
      keep in mind though, this is a 4 cyl t5, its not designed to take power. dont be surprized if it blows to peices.
      • TooManyCars
        • Dec 2004
        • 24
        i figured it would need to be stonger but no one can tell me what rwd tranny will bolt up and handle the power... I figured i would take the tranny to a shop and have as much upgraded as posible... I just realy love the 3.1turbo in my grand prix and would love to see what this motor can do with out the fwd traction isues..
        89&90 TGP auto
        86 GLX RX7 5 spd,
        84 dodge ram,
        • RebelGT
          • 642
          yeah, i have a 2.5 T5 trans bolted up to a 3.4 DOHC, same deal, it'll work fine.
          you can see pics of my similar situation in my build thread.
          http://60degreev6.com/showthread.php?t=29774&page=2
          26+6=1
          • sharkey
            • Jun 2004
            • 2061
            a t-5 from a v8 camaro would work. 2 big problems though, the v8 version uses a 1 1/8" 20 spline input shaft were the v6 (and 4 cyl) use a 1" 14 spline input shaft. the other issue would be the shifter, the camaro shifter is in a different spot.
            • TooManyCars
              • Dec 2004
              • 24
              ok well with a little searching .. I just bought a 89 s10 with a 2.8 5speed soo now i should be good to go .....
              89&90 TGP auto
              86 GLX RX7 5 spd,
              84 dodge ram,
              • kflo 93 gt
                Bangin' Gears
                • Nov 2003
                • 238
                Good deal. This sounds like a very interesting little project. Keep us posted on it.
                14.60 @ 96.33 for now...
                • TooManyCars
                  • Dec 2004
                  • 24
                  yah i remember seeing that someone had turboed a 4x4 s10 blazer ... but im pretty surre that was a 4.3 With both s10s that i now have i should be able to combine them to make one pretty decent little truck.. as soon as I get them both home i will take some pics and post them.....
                  89&90 TGP auto
                  86 GLX RX7 5 spd,
                  84 dodge ram,
