Engine running weird need help big time!
  • Jbrogan
    • Oct 2006
    • 203
    I changed my rockers on my 3.1 to the rockers off of a 3100. it ran like crap so i changed them back, now it still runs like crap. rough idle no acceleration, sounds like its running on five cylinders but all plugs are firing. I really need help if anyone knows what the problem is or has any ideas!
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    • 9191
    Did you put the wires in the right order?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      You could have bent a valve (That's if your wires are correct and not torn) .
      • Jbrogan
        • Oct 2006
        • 203
        yes i checked the wiring order and it is all correct. I think i bent a valve but im not sure. any other suggestions. i am going to do a compression test later.
        1996 Beretta
        3100 SFI TURBO
        • DEI37
          • Jan 2004
          • 516
          Kinda off topic, but why would wires make a difference? They shouldn't have come off anyways. Gotta go with a bent valve, or some such thing.
          • Jbrogan
            • Oct 2006
            • 203
            I checked the compression in cylinder 2 and it had about 10 psi. I bent a valve but im hoping its from the rocker slipping off not the piston. Is it really hard to change a head? its the front head.
            1996 Beretta
            3100 SFI TURBO
