I have recently installed a 3.1 in a dune buggy (out of a 93 grand prix) im using the volkswagon trans (002 bus) I have the engine running got rid of all the codes except for the VSS Does anybody know how to trick the computer that way I dont get this code anymore
3.1 liter dune buggy
THe ECM needs a VSS signal to properly make fuel trim calculations. I am not sure if the bus had the speedo on the drivetrain or if it was on the fron wheel like the bugs. But either way you should figure out a way to make a VSS.
There are boxes that will take a cable and convert to a VSS pulse signal for the ECM. They are also adjustable. You will ahve to search the net and see what you find.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
