3.4 crate engine compression test
  • MGAJIM
    • Apr 2005
    • 1
    Does anyone know the spec for the normal cylinder compression value? I understand "even" betwen cylinders is good, but at what pressure? Thanks.
  • gectek
    Banned
    • Aug 2006
    • 1472
    if you are doing a test, even in the books they will tell u higher than 100psi is the rule of thumb, but my 3400 ga gave me 130 on almost all cylinders and that was with 160k miles on it, not too bad. i think they are supposed to be within 20% from highest to lowest or something like that
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Yea 120 or more is good. But you wont get an accurate test on a dry crate motor anyway. It needs to be broken in first. The rings wont seal right until they are seated correctly after break in.
      • lowflyer
        • Aug 2004
        • 16
        Compression readings
        There can be some differences between gauges, but my 3.4 crate engine recorded 180-185# across the board with 1200 miles on it.
        One thought, make sure that your throttle body/carb is open when doing the compression check. If it can't breath it will be low.
        If I had all the money that I've spent on race cars back... I'd spend it on race cars!
        • gectek
          Banned
          • Aug 2006
          • 1472
          well if they arent sealing right you can do a wet test, kinda messy and time comsuming, but it gets the rings to seal
