05 3400 cam position wiring.
    I just need the pinouts on the cam position sensor for a 04-05 3400 its the plug that is right on the sensor, the newer style one.
    Pins are as follows, A-Brown/white, B-Black, C-Red/white
    I'm trying to splice it into my OBDII harness so I can use the newer sensor and wire routing my 96 OBDII plug/harness that I'm trying to splice it into has A-Red(Power), B-Brown/white(Signal), C-Red/Black(Ground)
    I just need to know the A, B, and C function on the 04-05 plug
  • gectek
    I Hate Nose Hair
    • Aug 2006
    • 1472
    from an 02 but should be the same
      They changed in 04 to a sensor that does not have a tail on it, the plug is right on the sensor at the block.
      Thats a pinout of the wiring that I know... I need one for the 04+ sensor, the wire color to pins are different...
      I guess I can assume that brown/white is signal, red white is power and black would be ground, but then again GM has done some weird things before.
