Intake Vac
  • PCGUY112887
    • Feb 2006
    • 1067
    Intake Vac
    On the 3100, how many inches of Hg should you be getting at idle for the absolute intake manifold vacuum?
    I just got an OBD2 scanner and I'm getting 11 inches of Hg, so I'm just curious.
    SpudFiles
    Theopia
    Enjoy life online.
  • black05gt
    Damn Yankee
    • 74
    Intake vacuum
    What RPM was that measured at ? I'm used to dealing in kPa , but I'm assuming it can be calculated ....
    ported 3500 heads, LIM, plenum, 28# TB FI's, TCE 65 mm TB, MPR CAI, F&R strut bars, F&R sway bars, Eibach springs, KYB GR2's, TOG headers, hi-flow cat, Borla muffler and tips, LC-1 WBO2, DHP PT
    • gectek
      Banned
      • Aug 2006
      • 1472
      it all depends on alot of variables, such as altitude for 1. if you know ur altitude then itll help. at lubbock the alt is around 33-3600ft i think. my vac is usually at 15 or 14 at idle, as long as the reading is steady it should be ok, i prefer to use a vac gauge on the manifold.
      • PCGUY112887
        • Feb 2006
        • 1067
        I said at idle... so around 600-700rpm's.
        It translates out to 37.25kPa
        My elevation - 565ft
        SpudFiles
        Theopia
        Enjoy life online.
        • gectek
          Banned
          • Aug 2006
          • 1472
          umm, urs should be around 16 - 18 i think
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Agreed. I pull 18".
            I have pulled as much as 22" engine braking in first gear down at steep ass hill at about 4000RPM.
            • PCGUY112887
              • Feb 2006
              • 1067
              Humm so anyone know why I may be pulling so much less? I thought the # was higher than what I was getting, hence why I'm asking.
              SpudFiles
              Theopia
              Enjoy life online.
              • gectek
                Banned
                • Aug 2006
                • 1472
                could be a number of things. how long have u had the car and how many miles are on it. has the engine been rebuilt? does it have the stock exhaust? has anything been changed on the engine?
                • PCGUY112887
                  • Feb 2006
                  • 1067
                  Everything is stock, about 117k, no rebuilds or anything...
                  SpudFiles
                  Theopia
                  Enjoy life online.
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    i think that you might have a bad cat. ive seen that drop the intake vac before. also the valves are a good place to start, but a sticking valve would make the reading jumpy. the best way to really tell is to get a vac/press gauge and hook it up to a manifold vacuum source and look at it. do a compression test and a cylinder leakage test to see if everything is sealing ok and that you have good uniform vac. other than bad combustion due to other causes idk more than that
                    • Guest
                      Agreed. I pull 18".
                      Mine was 18" to 20", some mornings would pull 22". This was on a hybrid, with 8.9:1 SCR, SP 3100 top end, GMP cam, stock port.
                      I pulled as much as 29 or 30 ONCE going down a hil, just to see my gauge go that low.
                      • PCGUY112887
                        • Feb 2006
                        • 1067
                        Well my mom has an 03 Buick with the 3100 on it, so I just went out and scanned it.
                        Exact same readings. Doesn't read throttle pos, spark advance, or MAF either, just like my car.
                        SpudFiles
                        Theopia
                        Enjoy life online.
                        • gectek
                          Banned
                          • Aug 2006
                          • 1472
                          what scan tool r u using
                          • PCGUY112887
                            • Feb 2006
                            • 1067
                            PCM Scan 1.5ish
                            SpudFiles
                            Theopia
                            Enjoy life online.
                            • gectek
                              Banned
                              • Aug 2006
                              • 1472
                              dont know bout that 1...is it a program or a handheld, and how much did u pay 4 it
