What year grand prix has a 3100?
  • ryan.hess
    • 526
    I thought they were introduced in 97 or something? I'm looking at a 95 with one... Is it an engine swap or am I crazy?
    Also, OBDII? Any way to pull the codes easily?
    Okay now, that's enough of that.
    • 9183
    3100s were introduced in almost all cars in 94, so a 95 GP should have one. Yes, it will be OBD2, and no, no easy way to pull codes. GM removed the option to pull codes without a scanner when they went to OBD1.5, and have been that way since...
    • ryan.hess
      • 526
      crazy... I must not have got the memo.
      Thanks,
      • PCGUY112887
        • Feb 2006
        • 1067
        Em no it won't be OBD-II, unless it's 96 or later.
        SpudFiles
        Theopia
        Enjoy life online.
        • Carlspike
          • Oct 2005
          • 154
          I thought 96 was just the deadline for all cars to be obd II and some got it a few years earlier. I've used the GM obd II scanner for my 94 2.0 with a connector adapter. Maybe thats the obd 1.5 bszopi was talking about.
            • 9183
            Oops, I mispoke... Was thinking 96, not 95. So yeah, it'll be OBD1.5, not OBD2.
            • 97cutlas$upreme
              • Oct 2006
              • 74
              obd 1.5 but if you ever need codes read for a obd 2 go to autozone theyll do it for free
              97 cutlass supreme
              3100 sfi
              cai
              ud pulley
              pu dogbones
              #14 rapidfires
              magnacore wires
              • ryan.hess
                • 526
                Went to advance, and they pulled out their scanner, but it wouldn't fit the OBDI connector.
                So I have a couple questions about that.........
                "OBD 1.5" is an OBDII computer with an OBDI connector, correct? Are the codes pulled going to be OBDI style - like "code 32- EGR" or OBDII style - like "Code P0234 misfire cylinder 2"??
                Second, I already have an ALDL interface. The nearest autozone is 6 miles away. Is there any software I can use to scan the codes myself?
