timing cover ?
  • rx191
    • 123
    timing cover ?
    I was wondering if any one knows if a RWD front cover will fit a 3400 block, i think there is a differnce but i can't find any info on it here
  • CNCguy
    Bisong eater :P
    • Dec 2003
    • 1017
    It will bolt on but there is a small hole in the cover that has to be plugged. I have a pic of a RWD cover on a 3100 posted in another thread.
    http://60degreev6.com/showthread.php?t=35472
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
    • rx191
      • 123
      sweet will the steel oil pan bolt up too, it would be much easier to modify that than cast one
      • CNCguy
        Bisong eater :P
        • Dec 2003
        • 1017
        Hopefully someone else can answer that for you as I really don't know for sure.
        I do know that the cast pan is supposed to add some strength to the bottom end of the engine.
        '79 MGB - LZ9 - T5
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          No it will not bolt up.
          • rx191
            • 123
            darn oh well, well at least the timing cover will work
