Fuel pump question
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Fuel pump question
    Would anyone know if the 95 Beretta V6 Fuel pump/assembly can be interchanged with a 88 Beretta V6 Fuel pump/assembly?
  • X11_STE
    • 386
    go to autozone.com and compare part #'s. If there the same, they will interchange, if not, then prob not. To the best of my memory, they should.
    Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Did that before I posted and it is indeed a different part number, but just maybe someone has had prior experience with something of this ordeal and can apply it in this thread.
      • 86euro
        • Dec 2006
        • 219
        I believe they are the same, but maybe the '95 is rated for a bit more flow. The '95 may have a newer style connector, but an '88 new replacement probably will also (new pigtail included).
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          I am not going to chance an OEM pump with a non-N/A engine.
