Tach Questions
  • 3.1cutlass
    • Feb 2007
    • 101
    Tach Questions
    Ok so i have aquired a tach and now i want to install. It has 4 wires green, white, black, and red. I know red is power and black is ground. What do the green and white wires do and where would i hook them up on a 3.1 mpfi?
    • 9191
    Green is probably for the light, and white is the signal wire. Connect that to the ICM (6-pin connector) as shown below:
    • 3.1cutlass
      • Feb 2007
      • 101
      so where can i find the icm
        • 9191
        The ICM is in the engine compartment and is the module that the coil packs sit on top of. So on a 91 Cutlass, it would be near the oil filter IIRC.
        • Guest
          Nope, Green is tach, white is light, congrats you almost blew up the tach.
          • 3.1cutlass
            • Feb 2007
            • 101
            i havent tried anything yet
              • 9191
              I'm sure reading the instructions would clarify the wire colors as well. But maybe that would make sense... And I haven't hooked up a tach in probably 15 years, so I was basically guessing (hence the "Green is probably").
              • 3.1cutlass
                • Feb 2007
                • 101
                well after finding the online manual for the tach i found a wiring diagram. I am seeing the black=ground red=12v white=dimmer green=signal
                  Yup, the white C tach signal on the 6 pin connector.
                  I almost installed a tach in my car until I found a full gauge cluster for my car. Looks much nicer.
                  • Ray Hamilton
                    • Feb 2007
                    • 239
                    Tach
                    What kind if tach will work on an '86 2.8 S10? And how would it hook up?
                    '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
                    • kill_them_all
                      • Jul 2004
                      • 96
                      Any tach will work, hook them up to the negative side of the coil.
                      • Ray Hamilton
                        • Feb 2007
                        • 239
                        Which side of the S10 divorced coil is the negative side? Two plug ins going to it.
                        Thanks
                        • geoffinbc
                          Iron Head Enthusiast
                          • 5831
                          The 2 plugs are really 1. The pink is power and the white is the signal or negative side. Either plug can be used they are effectivly spliced once plugged into the coil.
                          • Ray Hamilton
                            • Feb 2007
                            • 239
                            Thanks alot, again.
