Crate 3.4L vs 95 Lumina LS
  • Tofuball
    Drives a giant grey brick
    • Feb 2007
    • 45
    As long as you use the coorect pistons with the heads, you will yield a "stock" CR for that engine. You said you had a donor motor for parts?
    It's true!
    But if I can avoid pulling apart my bottom end, I will :P (It's only got 10K on it)
    I wouldn't mind getting a C/R closer to 10:1, but anything over that is a bit much for my purposes.
    • Tofuball
      • Feb 2007
      • 45
      Well, using the site's CR calculator I figure that with a 4mm head gasket, I'd have the CR in a good place.
      Anyone make one? That would be too convenient though . . .
        Live life 3.7mi at a time
        • 4555
        That's .158" ! .060/.040 are stock sizes. If you have that much gasket, your quench would be really high. Most people strive for .040 quench.
        • Tofuball
          • Feb 2007
          • 45
          Hrm. I'm a rotary mechanic, your piston engines confuse and anger me! Whats with all these moving parts!? :P
          . .. thanks for the info
