never seen this happen to a starter
  • 3100 MPFI
    • 1522
    I finally got around to replacing the starter in my STE. I think I will let the pics do all of the talking.
    Taylor
    1998 Lincoln Mark VIII
  • 86euro
    • Dec 2006
    • 218
    I've seen one do that before, but that was after I got mad at it and threw it down on the concrete, lol.
    • 3100 MPFI
      • 1522
      Anger did not do this one. Unless the starter was angry and decided to commit suicide.
      Taylor
      • sharkey
        • Jun 2004
        • 2061
        if the starter did that to itself it was likley an Emo starter and very depressed. cutting itself didnt get your attention so it had to break a peice of itself off.
        i have seen that when the starter gets worn out. if the bearings start to wear it put a lot of load on the housing and if the motor kicks back a bit, it can break it.
        if you didnt have a pic of the new starter beside it i would have sugested a 2000+ 3400 starter. a bit more money but a bunch more cranking power and lighter
        • 3100 MPFI
          • 1522
          I wanted to do the newer starter, but I have had this one in storage forever and a day, so I figured I might as well use it. Besides, the small starter is going into the gold car once the OBD2 swap is finished.
          Taylor
          • Rhedalert
            Dr. Feelgood
            • 1574
            that sucks!
            Brian
            3400 SFI V6, 4T60e
            • X11_STE
              • 386
              I actually expierenced something VERY similiar to this on my X-11. My starter died as a result of the throw out bearing letting loose and cuasing the clutch to shatter!! Result: a starter in 5 pieces!
              Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
              • KlingonFiero
                • Mar 2007
                • 68
                I know that the odds of the same thing happening again is real slim, but I had the same starter explosion happen to me, twice within a month...
                It turns out I had the wrong shims and the starter was actually catching on the ring gear.
                Check your shims, just to be sure
                • 3100 MPFI
                  • 1522
                  there were no shims in there, but it sounded fine. As it is now, I don't have shims, but I can tell it needs them. I have some in my moms storage building, but she paid the bill LATE, so they put a lock on it, and I cant get into there until monday.
                  That just killed all my plans for the weekend. All of my parts, and some of my tools are in there.
                  Taylor
                  • KlingonFiero
                    • Mar 2007
                    • 68
                    That sucks..
                    Do you know how to check for the right clearance?
                    The shims come in a set of different thickness'.
                    Good Luck on Monday.
                    • 3100 MPFI
                      • 1522
                      yeah, I know the drill. Storage is locked up right now, so I cant get in there to get my shims. I just might check to see if I have one of the small starters. Those don't need shims.
                      Taylor
