Hows this happens with only 36k miles?
  • loner666
    • Oct 2006
    • 435
    motor was put in 4 months ago..all new gaskets and a new timing chain..so i have no idea..going to pull the timing cover later this week and see if anything strange is going in there..cam is fine
    Rear Head
    Front Head
    All 6 pistons have this little knick (wasnt there 4 months ago)
    Cyl 2 exhaust pushrod
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    • 9186
    How much lift on the cam? Cause that little knick sure looks like a valve is hitting.
    Far right exh. valve in the 2nd pic looks like it has a knick on the outside edge as well.
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      wierd, looks like the timing chain jumped or somthing
      also looks very oily for 36k
      did it just all the sudden go bad and you couldnt start it again?
      • 86euro
        • Dec 2006
        • 218
        Am I seeing things, or are all the exhaust valves bent?
        • 3100 MPFI
          • 1522
          I have knicks like thoes on my pistons. Happened when the pistons went up, and the valves went down.
          I had to replace both heads, and reset the timing.
          Taylor
          1998 Lincoln Mark VIII
          • loner666
            • Oct 2006
            • 435
            everything engine wise is stock other then LS6 valve springs..they may look oilly from the way i had them sitting and from removing them and since it hasnt ran in a month..i havent cleaned them since i installed the engine..all the exhaust valves may be bent..i know atleast 3 are noticeable..not to worried about the heads..i have new ones sitting here waiting already
            car was running fine..left a light being easy and thats when it went..no power at all..ran but not willingly and sounded like shit for the few seconds i could get it to run..now i know why..lol..im gonna check the chain later this week and see what i find
            Daily Driver
              As I replied on the bstuff board if you find that the chain jumped a tooth, my jaw will drop... I'm unsure on how something this tight could jump a tooth...
              I'll share this with this crowd, but in my opinion I think he broke the cam timing tooth off...
              Is that possible if the cam bolt isnt tight enough?
              this is the tooth I mean. better known as a dowel/pin I guess...
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                I suspect that center guide to be broken allowing massive chain sloppage which could allow timing to jump a tooth or two.
                • loner666
                  • Oct 2006
                  • 435
                  if i rememeber right i torqued the bolt to what it says here on the site..also that guide wasnt broken 4 months but who knows now
                  Daily Driver
                    if the chain stretched it's pretty easy to jump a tooth or 2.. It's possible that the crank key broke... seen that a few times.
                    If that pin broke off on the cam the car wouldn't run at all.. even at 100+ lbs of torque on the cam bolt the sprocket would still rotate pretty easy w/o the pin.
                    Scary stuff.. in for more carnage pics...
                      Carnage FTW!!!
                      HAHA just kidding.
                      • Rhedalert
                        Dr. Feelgood
                        • 1574
                        subscribing
                        Brian
                        3400 SFI V6, 4T60e
                        • loner666
                          • Oct 2006
                          • 435
                          lol..ill have more picture this weekend when i have time agian to work on the car..i dont have the time to do it between work and school during the week right now..damn finals
                          Daily Driver
                          • 1988GTU
                            LB62LHObbqftmfw
                            • Nov 2005
                            • 2475
                            email notifications... on.
                            • loner666
                              • Oct 2006
                              • 435
                              Got the cover off need a new cam..the little pin broke off..ill get pics when i get my camera back tomorrow
                              Daily Driver
