Correct wiring for a CS-130D alternator?
  • 95 V6 J body
    • Jul 2007
    • 40
    I have an 02 3100 motor running on 95 F-body ECU, and I am trying to wire up the alternator (CS-130D). I found and downloaded a wiring diagram from hotrodlane.cc, that shows a 4 wire plug with wire colors, however I don't have a plug with those color wires on it. I looked at the picture and hooked up the wires that looked correct according to the diagram, and I'm still not getting charge. Can anyone shed some light on this?
  • 95 V6 J body
    • Jul 2007
    • 40
    update: I got it taken care of. The wiring diagram I downloaded is not right. It may be correct by the color coding IF you have those color wires, but it's not correct by pin. according to their diagram, you need to use pins 1 and 2, when in reality it's 2 and 3.
