anyone know if the 3.1 injectors will work in the 3100 in a 96 Grand Prix? I am having a sputter issue and to me its leaning toward injectors. thanks
3.1 Injectors in a 96 3100
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built carTags: None
Yes, they will work. Pretty much all injectors from GM engines are interchangeable (given the same flow rate) up until they came out with the Multec II's, which are a lower impedance.
ok thanks very muchRobert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
It will not run right. The spray pattern is different.
I tried using 3100 injectors in my 3.1 and it ran like crap.Taylor
1998 Lincoln Mark VIII
This is just a guess from what I've been told about the different injectors, but I would imagine that it would run, but would run lean. If thats the case then a computer tune would fix that but for the money you'd spend to get your computer tuned you could probably get some used 3100 injectors. You could also send the injectors away to have them cleaned and tested.
Here's the link to the article : http://60degreev6.com/showthread.php?t=25017
And here's the home page of the place that does it : http://www.witchhunter.com/Last edited by TazMan; 08-02-2007, 01:34 AM.
3.1 injectors are lower flow rate that 3100 ones. If you need a set I have a few lying around.
