Just wondering on the complexity of a 3.4pr swap into a 1988 2.5 5 spd S-10. Also maybe swapping 3400 piston,3500 heads ,intake and different ECM.
3.4pr swap into 2.5 S-10
Well about the only thing that will work is the transmission. Otherwise pretty much everything else is different. Are you planning on using a RWD block from a Camaro or using a 3400 motor?1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Well I was thinking about a camaro block with 3400 pistons, heads and intake. I was looking at an S10 for my son but it has problems. I think I got this in the wrong catagory, I didn't see the swap section ,sorry. Well guess I'll keep looking for a S10, no deal is better than a bad deal.
Well it is a nice swap but does have its difficulties. If you are experienced with swaps it should be fairly straight forward for you. It would be easier to start with a 2.8L S-10 if possible.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
