E85 - conflicting information
  • ahazuarus
    tinkerer
    • Mar 2007
    • 32
    They say e85 is bad for a non flexible fuel vehicle (ffv). Some say just the opposite. Others say that a full tank every now and then is very healthy. Some evidence exists that problems may never even surface.
    E85 is readily available in my area and the price is right. Some have recommended filling up with E85 before taking a trip up into the mountains, the added power is highly useful. This would certainly help me out.
    Vehicle in question: '98 Olds' Acheiva v6 (3100)
    No "conversions" have been made yet. Thanks for your input!
    2001 Chevy Impala (3400)
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Well for one there is NO added power. In fact you will loose power if you fill up with E85. And since your vehicle does not support it the ECM will not know your running it and your fuel mixture will be off. The only way people get more power from E85 is because you can run a really nice compression ratio because it has an octane rating of 120. Alcohol will break down the seals and plastics used in the stock fuel system over time. I would not bother with it nor risk it.
    Now it is a different story if you build a motor specifically to run E85 because you can get more power from it with a high compression. Also it works miracles for boosted motors despite its octane rating alcohol fuels have a very high refrigeration effect on the incoming air charge.
      It will also corrode the system as it absorbs water like crazy.
      If any pumps say "E85 Recommended for Flex Fuel Vehicles" They are illegal and should be shut down. It should say "ONLY for Flex Fuel Vehicles".
      • Guest
        e85 is not 120 octane. Its 106
        • Carlspike
          • Oct 2005
          • 154
          Without a higher compression ratio E85 will also get worse fuel mileage. Your injectors may even have a hard time keeping up. Unless you have an engine built for it (and the correct fuel components) then I wouldn't risk it.
          • geoffinbc
            • 5831
            Yea could be I was going off the top of my head. But in either case it is still a sweet octane rating.
            • treeZ24
              i wanna go fast!
              • Mar 2004
              • 251
              there's a guy over on the v6z24 boards that is using e85 on a stock gm fuel system (3400 turbo swapped) and a tune + bigger injectors to compensate for the additional fuel requirements.
              so far there are no effects known.
              got zap-straps?
              89 Z24
              13.886 @ 96.16 mph
              street trim - slicks
                Yeah Scott he's over here too. He sold his stuff and now is building a new setup.. He may be fine, but if he were to run it for 5 years or so then who knows??
                • geoffinbc
                  • 5831
                  Ha ha well they can have fun with E85 for a little while but soon enough the seals and plastics will all fail.
                  Car companies didn't invest millions in new products and materials to run E85 because they felt like it.
