FUEL ECONOMY whoes
    Denso O2's are nice. I'm running one and happy with it. www.sparkplugs.com has them for cheap. IIRC the new ac delco O2's are denso, and the sparkplugs are ngk. But branded Ac delco..
    • 85_Olds_Ciera
      • Aug 2007
      • 259
      Originally posted by IanSzgatti View Post
      whats the difference with these two listed above??
      Here's a photo of a 4T65e clearly showing this electrical connection where we have a device under test plugged in. This is missing on the 4T60e.
      • IanSzgatti
        • Oct 2006
        • 519
        damn man! crystal clear on that... thanks!!
        • IanSzgatti
          • Oct 2006
          • 519
          Rather than start another thread... i thought i'd mention in this one what I have found...
          At lunch today I brought my car into the shop, and while chewing on a bologne sandwich plugged in the snap-on scanner.
          I notice the LTFT is stays around -17, (STFT plus 1) indicating the PCM is continually cutting fuel...and the engine is therfore running rich.
          02 sensors are fine
          CTS is reading correctly, confirmed with pyrometer
          IAT sensor is operating correctly
          instead of listing all the common go to sensors, we'll say there ok
          (edit: how many GPM should the MAF read while at idle?? anyone know that?)
          I was thinking about the fuel pressure regulator or an injector fault... unfortunately i wasnt able to do an injector balance test, but i did put some vac to the FPR... it seemed it didnt leak...obviously... but im wondering how much pressure it should be able to hold...
          I'd also like to know a little about the ohm rating for a healthy 97-99 3100 SFI injector... common problems? shity injectors? prone to clogging?
          anyway.... this whole time i though a vac leak was causing my loping idle... but the LTFT numbers indicate it's fuel system related... anyone care to take a stab at it before I solve the case??? you'll win nothing.
