Pulling 3.4 from F-body in salvage yard
  • jwvess00
    • Oct 2006
    • 63
    Hi there!
    I've found two 4th gen F-body cars in a local salvage yard, and the price is right on the 3.4V6 engines they've got. The cars are sitting on old rims and are stable, so access to both the top and underside is pretty good.
    The yard will loan me a hoist but will not pull the engine for me. I'm not allowed to use a torch, either. Dad and a friend will help, so at least we have up to three people wrestling with this if necessary. If nothing else, I can wrench and they can swear for me
    Any tips on pulling the engine out? Unfortunately I won't have access to electricity (no generator) or compressed air, so this is a hand-tools-only job. I've had V6/60 engines out before (S-10s), but I've never pulled an engine from a 4th gen F-body.
    Thanks!
    1982 Chevrolet S-10 Sport, 2.8V6 TBI
    2006 Pontiac Solstice
    Live life 3.7mi at a time
    • 4555
    You're going to want to tip the engine back to get to the two top bell housing bolts, or pull the engine and tranny together. Some people have made holes on the hump inside the car to get to them if you have a way to cut (hole saw on cordless maybe).
      IIRC the easiest way on those is to drop the engine out the bottom... or atleast that's what the V8 guys do.
        • 4555
        Those kind of yards stack rims and weld them together, then weld the rims on the hubs to the stack. The car would have to be supported somehow to get the k member off. Most of the 3800 guys I talk to pull the engine and tranny together because of those infamous top bell housing bolts (3800's use the small corp 60* pattern).
        I could definately see why the v8's would go out the bottom in a 4th gen.
