Two simple questions
  • 2.8RS
    Cone Murdurer
    • 196
    First I want to know if a 2.8 from a 86 Cavalier will swap into my 89 Camaro, I'm not sure if the Cavies back then were FWD. I know that it is an iron head motor but if I have to do motor mounts a such then forget it. There is one in the local paper for a good price.
    Second, does anyone know the stock diameter of the exhaust port or the iron heads, for my 89. Thanks.
    00 Grand Prix GTP Daytona
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Cavaliers were always FWD. The install would require new mounts.
    The actual port opening is around 1" in size. The valve is 1.42"
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Isn't the starter a concern that will need to be addressed? IIRC the oil pan might be another issue to look into.
      • 2.8RS
        Cone Murdurer
        • 196
        Yeah they are, I'm not going to pick it up. For some reason I thought the old ones were RWD.
          oh man, that would be badass.... I'd have one if that was the case
          Yep, always FWD.
          • geoffinbc
            • 5831
            If you want a RWD car the size and weight of a Cavalier, get your hands on a Monza or one of the sister cars from Oldsmobile or Buick. I think an LSX powered Monza with a 6 speed would be bad ass. Or maybe one with a 3.6L DOHC.
