3.1 injectors
  • montess408
    • May 2006
    • 391
    3.1 injectors
    what is the rating in lbs of the stock 3.1L injectors ? i am building a 3.1/3400 hybrid and i am wondering what injectors to use i got my eye on a set accel 21 lbs but i am wondering if they are to big or not ?
    i am using camaro pistons and a crower cam 290/298 .470/.492 and just stock 3400 with ls6 springs it will have headers mns ingnition and also a 125 nitrous wet shot for the track !!
    any comment would be aprecited
    thanks
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Between #16 & #17 @ 43.5 PSI. I have some GM 1996-1995 #21 @ 43.5 PSI that I'd be willing to part with. I also have some 1995 Olds #23 @ 43.5psi 3, but dont know if they can be used in our platform.
    • montess408
      • May 2006
      • 391
      i think that they are the mulitec ones i am not sure i want the ones that can plug right in to the harness
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        IIRC the ones I have are all M1's and require the use of stock harness plug ends.
          21-24lb/hr should be perfect with a little tuning...
          • treeZ24
            i wanna go fast!
            • Mar 2004
            • 251
            late model 3400 injectors or 00+ 2.4L Quad 4 injectors should work quite nicely.
            got zap-straps?
            89 Z24
            13.886 @ 96.16 mph
            street trim - slicks
