underdrive pulley
  • beretta5
    • Dec 2007
    • 9
    underdrive pulley
    were can I get underdrive pulley for my 91' Beretta 3.1?
    were can I get a strut brace for same car?
    I know MRZ has them, but is there any place else?
    Thanks.
  • andrew383
    • Nov 2007
    • 70
    asp sells the udp as well
    sigpic03' 3100 slp cat back-custom fwi-gmpp trailing arms-mrz udp-aeroforce
    • beretta5
      • Dec 2007
      • 9
      do they have a website?
      • beretta5
        • Dec 2007
        • 9
        OK, I did a search and found it
        Question.....where can I get this "damper" I read about for 8 pages?
        I scanned through the post, will sit and read it when I get time.
        But it appears I need to get the damper when I purchase the UDP....this is going in a circle track car that will see around 5,000 rpm often
        Any help will be appreciated.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          When you get a UDP you are forced to remove you factory damper. There is no way to reinstall one so basically you are taking a risk when using an after market UDP because no one makes a proper one. The factory damper and pulley are the same component on a factory motor.
          • johnnymossville
            • Jul 2007
            • 255
            Go to E-bay Motors, Parts and Accessories, and type in Chevy Beretta. I have seen numerous strut bars in there for around $20. I believe that the Cavalier strut bars also fit on the Beretta/Corsica as well.
