60V6 block numbers
  • Blue89rs
    • Mar 2004
    • 36
    60V6 block numbers
    Is there any reference anywhere as to what the block numbers are for the various versions of 60V6? Namely, I'm looking for is how to tell the difference between the 1st and 2nd gen 2.8L blocks. I'm looking for a number response so I can make an absolute conclusion.
    89 RS - 3.25L V6
    89 RS - 5.7L LT1
    87 S10 - 2.8 flatbed, RS wheels
  • Corpse
    • Mar 2004
    • 110
    There was a rebuilding site that told everything. Info on all the castings, i'll see if I can get it. It even describes which blocks are stronger.
    If I seem Crazy it is because, I am insane. No lie. Ask my psychiatrist. But, i have good intentions. sometimes.
    • robby1870
      Squaddoosh
      • 584
      And, the vin letter is stamped on the side.....or atleast it is on my porject motor's 3.1L
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
        • 9191
        Newer blocks are different. The 3400s have an A cast into the side, whereas the 3100s have a B cast into the side. Not sure when they started doing that though...
        • Blue89rs
          • Mar 2004
          • 36
          I noticed some numbers on the top by the timing chain cover but I forgot to write the numbers down this morning.
          89 RS - 3.25L V6
          89 RS - 5.7L LT1
          • Corpse
            • Mar 2004
            • 110
            "1st and 2nd gen 2.8L blocks" - Well, I couldn't find the link I was looking for but, it had everything...
            Anyhow, does anyone know this, I don't think any 1st Gen's would have been built drilled for the crank position sensor? If so, that would be a good identification.
            Of course, I think some of the GenII or 3 blocks that were used in some vans and stuff with a distributor may not have been drilled either.
            I'm not really too sure of this though.
            • Blue89rs
              • Mar 2004
              • 36
              Numbers in the location mentioned before are:
              A090329ABL from my 89 2.8
              T0526DAD from an 86'ish
              89 RS - 3.25L V6
              89 RS - 5.7L LT1
