Need Help/Suggestions....!!
  • lkurek
    • Aug 2006
    • 153
    OK...first the stats: 3100 in a 95 Lumina, 285K miles. Mobil1 ALL the time, and the inside of the engine is like new.
    How do I know what the inside of the engine looks like....? Well.....
    I was driving the other day, about 2blocks from home, when I heard a pop...the oil pressure light comes one and the engine runs like crap and dies. WTF....was running fine until then, although earlier that day there was a slightly louder than normal lifter tap. Got it fired up, but a)no oil pressure, but no rod knock. Ran, but had to keep it almost floored to get it running and home.
    Upon teardown, I expected to see a chucked lifter that caused the drop in pressure and lack of all cylinders firing. There was no sign of any problems on the outside of the engine....and no oil in water or water in oil.
    That was not to be. I found a blown LIM gasket on the rear head by the thermostat crossover. Damn! I guess the engine was wiped....or so I thought. I also found that the # 3, 5, and 6 intake ports were fairly full of fuel. Weird.
    Sooooo...I have been debating an engine swap. I have a 3400, a 3.4DOHC, and a 5.3LS4/4T65ehd combos available..... Since the car is old, and it's cold....I was going to go the easy route and just drop the 3400 into it. But as I was driving around today....I still couldn't figure out the gas in the ports thing. Then it hit me....no oil pressure, and no valve action on the back three cylinders....broken cam? When I got home, I put a wrench on the crank and sure enough....front of the dam rotates, but the back doesn't WTF!!! A broken cam! Unreal.....I have never seen this before.
    So, now I need a new cam/lifters......anybody have a set they want to sell?
    I'm still debating the 3400 install, as it probably is as much work to change the motor as it is to change the cam.
    My questions:
    1) What would cause the cam to break like this?
    2) If I were to put a new cam in....what else besides lifters and timing set should I also install?
    Unreal.....I have never seen this happen....
    Finally, MAJOR kudos to Mobil1! I ran the engine for maybe 2-3minutes, up a hill even, and not a rod knock to be heard. Engine still rotates smoothly....
  • TDIXON
    Red Monster...
    • Dec 2007
    • 102
    once your limg blew it orobably got a little water on cam and seized it causing it to break. plus iirc these cams are hollow for certain years. dont remember exact years tho. and if you put a new cam in you will want to replace cam bearings also.
    1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
      • 9191
      I have heard about broken cams several times, and even have half of one sitting on my desk (found in a JY). The hollows cams started in 93/94 with the 3100, and continue to this day.
