3.1 turbo questions
  • montess408
    • May 2006
    • 391
    3.1 turbo questions
    i was looking for info on the 3.1 turbo motor and cant real find anything
    do they have forged pistons stock ?
    is the cam a diffrent one than the stock n/a 3.1 ?
    what is the limits of the stock turbo ?
    are the heads and intake the same as the n/a 3.1 ?
    thanks guys
    thanks guys
    no, the pistons are cast
    Same cam
    10-12PSI.. maybe? the T25 is pretty small, alot of people upgrade
    Yes, the entire top end is the same aside from the writing on the plenum.
    the SCR change is rumored to be lower due to either a slight deck height increase, slightly larger dish in the pistons, or a GM tech fudging the numbers.
    • montess408
      • May 2006
      • 391
      so there is nothing special about it then
      hypertec pistons should hold up better then stock one then right ?
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Everything is the same.
        Compare these specs to the tgp and you'll find that they are the same.
        People have pushed 18psi through the Gen2, headgaskets become the limiting factor before the lower end starts to let go. However, you should be at about +350hp/tq before you start to see stuff blowing/falling apart. Don't be surprised if you go through a few transmissions/parts getting to that number.
        • kuntzie
          • Sep 2006
          • 21
          i have ran over 18 psi on my 3.1 turbo, dynoed 302 whp and 409 wtq on a rough tune and hitting fuel cut at about 3800 rpms and im going for over 400 when i go in nex week (still on the stock botom end)
          • montess408
            • May 2006
            • 391
            so you dont really need forged pistons to boost then ? i know it's probley better but if your pushing 18psi on cast pistons would'nt hypertec pistons hold up to the same or more ??
              it's all in the tune...
              • 1QUICKHATCH
                • 387
                Same cam
                the turbo 3.1 heads have different chambers! they look a little more like a 3500 chamber
                14.96@91.47 in the 1/4
                9.63@74.36 in the 1/8th
                  the N/A 3.1 heads have a similar shape as the 3500 as well.. they all have the "fastburn" shape...
                  i have some heads from a 3.1 in the garage if you'd like to see a pic
                  • 1QUICKHATCH
                    • 387
                    they are not the same as the N/A heads. the chambers are rounded off more. I will try to get pics in a few weeks. the turbo heads flowed a few CFM better too, but that was most likely just the casting.
                    • GutlessSupreme
                      • Nov 2004
                      • 166
                      asdf
                      -Tony | gtsdurango.net
                      '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
                      '90 Turbo Grand Prix STE - ehh.. I'm working on it.
                      '92 Gutless Supreme SL - RIP 5.2010
                      '90 Turbo Grand Prix - RIP 6.15.2005
