DIY Ceramic Coating
    they say NOT to oven bake it, I'm not sure why, but I guess you just need to be carefull going in... yeah i know not easy.
    I'm using the supplied polishing liquid that came with the kit... Nothing too special I dont think.
    Now if my trans was closed up i would be able to bake this on but since I'm still shy parts I cant do that quite yet... I either have to wait for EP or leave early from work to go to the yard and buy another diff.
      This is what I got it to buffing more at work... Also was able to touch up the small spots that chipped a little due to water being under it, I just used a tooth pick, dipped it in and rubbed it on the part, worked like a charm.
      Now I just hope it sticks...
      • IsaacHayes
        Mr. Orange.
        • Apr 2006
        • 6030
        Did you de-grease them with brake cleaner and rub them down first or just dish soap and water?
          Black beauty blasted them to strip all the paint off, then used Por-15 metal ready and then wiped them down with acetone before coating.... as instructed.
          • Wiz85
            N/A all the way
            • Feb 2008
            • 48
            let us know obviously if holds up after engine start up
            Eric
              I should know the answer of that one by tomorrow night if my EP LSD shows up during the day.
              • Chris88CL
                Moderator
                • Dec 2003
                • 212
                #22
                And?
                  Ok, well an update, so far so good, BUT I think prep is really the biggest thing here... I might have missed the smallest spot with cleaner right on one of the welds by the collector... so far that is the only spot it has flaked, and its like a tiny spot... I also chipped the front with the fan going in... I was rather pissed about that one, but that I should be able to touch up with a q-tip and the paint, and then bake that back on... the Q-Tip works good because after that you polish it so you sort of take down any unevenness... I'm gonna try to see ifthey polish up some more now but honestly I dont care if they stay gray like the color they turned... as long as they dont rust!
                  I'll get pics later today.
                    Here are some pics...
                    Only part thats flaking right now.
                    And the chips I did... ###### FAN! LOL
                    Overall shots.
                      Still looks nice though
