Low coolant light on....
  • ecko614
    • May 2008
    • 94
    i am in need of some suggested help...my low coolant light popped on yesterday and everything was runnin good and what not.....let the engine cool down, checked the reservoir-full. Laid down undernesth and noticed a small puddle of coolant-bout the size of a 50 cent piece. checked the hoses and everything was tight and fine. Checked the reservoir today-bone dry and no puddle on the ground. Any idea??
  • 3100 MPFI
    • 1522
    it may or may not be something to be concerned with. I would fill up your resevoir to the proper level, and just keep an eye on it.
    I know that with the current temperatures getting hotter and hotter, the cooling system needs to adjust itself, so it could just be that. It could also be your thermostat stuck for a bit, then finally opened, up, or that just the coolant level sensor is going out.
    Since your resevoir was bone dry, it might just mean it had emptied out, and had to readjust itself.
    I know right now that in my 1995 Cutlass Supreme SL 3.4 DOHC, last night, the low coolant light came on, but it was not at full brightness. The coolant is fine, so I don't know what it means.
    When the light normally comes on in my car, then it is REALLY bright, and this one was kinda dim, but it was definatly ON.
    Taylor
    1998 Lincoln Mark VIII
    • jonbourg
      • Jun 2008
      • 18
      My coolant light comes on all the time. The cap is loose on the reservoir (18 yr old Lumina). Maybe your having the same problem? Open the radiator cap when cool and make sure you have coolant up to the top. Top off the radiator and the reservoir. Then start the engine and let it run till warm and open the bleed valves and you should have water coming out of the bleed valves in a steady stream not steam or sputtering. Once you do that you should be fine. Just keep an eye on it in case of a leak somewhere.
      • ecko614
        • May 2008
        • 94
        how do i bleed it?? somone else told me the same thing. My reservoir cap is fine....so, i dont kno. my radiator doesnt have a cap....now that my coolant system has about 80% water in it, im guessing its evaporating quicker because its more water that actual coolant but i dont know. im bout done with the damn car.....just changed the spark plugs and the damn engine ticks now....kinda sounds like a faint "chika-chika" sound. is that a spark plug not tightened down all the way?? they are gapped properly, but it started after i was told to take out my bosch's and go back the deco's. Changed them and here we are.....
        • geldartb
          The Situation
          • May 2004
          • 1994
          hows your oil look any milkshake look to it and any different looking substance on the oil filler cap.
          from previous experience and from what other people have reported usually when the low coolant light comes on its time for the lim gasket change.
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
          • SuzukiGhostRider
            Beretta Freak
            • Apr 2008
            • 118
            To bleed your coolant system ,take the res cap off and start the car. Let it idle for about 20 minutes. You should see air bubbles coming back through the res tank if you have air. Put the cap back on , let it cool down and repeat. That should do it. GL.
            • geldartb
              The Situation
              • May 2004
              • 1994
              theres also a bleeder screw in the area i circled on the tube running into the firewall
              99 Grand Am GT
