2.8 timing cover
  • montess408
    • May 2006
    • 391
    2.8 timing cover
    hey guys i am looking for a pic of a older timing cover off of a 2.8 where they like a sbc cover ?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    No they never were. They are always cast aluminum. The Early FWD and RWD ones had a water pump that sat in the middle of the motor while the later FWD models had an offset pump.
    You cannot get a cover that only covers the chain with a pump that is separate.
    • montess408
      • May 2006
      • 391
      would it be possible to machine off the water pump part off i wonder ?
      still looking for pics both sides close up if possible (rwd camaro)
      thanks !
        Live life 3.7mi at a time
        • 4555
        There's plenty of pics in here of the 3.4timing cover
        EDIT: You have to remember the 60* is very narrow, that's why the timing cover and water pump mount are married.
        • geoffinbc
          • 5831
          I suppose you could machine the pump section off. But you would have to figure out how to get water into the block. Maybe use a remote pump? Maybe with tubes pressed into the front of the block and then attached to piping
          • montess408
            • May 2006
            • 391
            well that is what i have in mind ! it's for a drag car and i saw alot of or guys running a electric pump off the side and it's plumed with braided hose or copper pipes so that's what i would like to do because of the lack of room in the engine bay
            • geoffinbc
              • 5831
              Yea I am sure you could do it then. I would either put threads in the block and screw in a pipe or press and solder in brass pipe.
              Screw in ones would be better for service. I wonder how big NPT to AN fittings come? You may be able to use that. Standard stuff is always easier to work with.
                • 4555
                Are you just going to hack up a stock cover to only keep the oil in?
                • montess408
                  • May 2006
                  • 391
                  yeah that was the plan i guess
                  but i am open to any other ideas
