Engine dies when vehicle is clutched.
  • cardana24
    • 434
    I have a 3.4 in my jeep cherokee. When I clutch the vehicle coming up to a stop sign the rpm's dip down low and the engine dies. This only happens when the vehicle is up to operating temp, it works fine when the engine is cold. How can I fix this?
    Currently I do not have the Vehicle Speed Sensor hook up, and I do not have a brake switch hooked up (I thought this was only necessary for automatics, and I have a manual trans.) Would either one of those being un hooked cause this problem?
    Any ideas?
    • 9190
    Do you have AC hooked up? If so, see if your idle changes when you turn on the AC. I'm just wondering if your IAC valve is operating properly. If not, then you could see the symptoms you are describing.
      VSS not hooked up is your problem. I'm pretty sure of it.
      Since the trans is turning the engine when slowing down, then when you push in the clutch it no longer is being turned and the ECM doesn't expect this and the engine speed drops too fast for it to react. I believe I've heard of others having this issue with VSS not connected. If it was connected the ECM would know you are slowing down and see that the RPMs are high and figure out what is going on and anticipate it better.
      • cardana24
        • 434
        AC is not hooked up.
        I'll look into getting an adaptor so I can run the VSS.
        • cardana24
          • 434
          Would any of these sensors work for me? I want something that fits with little to modification, and I don't want to loose the function of my speedometer.
          • CNCguy
            Bisong eater :P
            • 1017
            I vote for the VSS as well.
            Be sure to get a VSS that has the correct pulse/rev output. Too many pulses/rev and the ECM would think your Jeep was going much faster and would hit the speed limiter at a lower speed.
            MinusOne - 3100 - 4T60E
            '79 MGB - LZ9 - T5
            http://www.tcemotorsports.com
            • cardana24
              • 434
              Do you think any of the ones on the site I posted will work? I need one that is 4000 pulses per minute and I see one on that site. But how do I make it work with my current speedo? I do not have a digital speedo. I need something that will work while maintaing my cable driven speedo.
              • CNCguy
                Bisong eater :P
                • 1017
                I am no expert and not the one to advise you on this. Perhaps someone else who is knowledgeable will jump in with some info for you. My post was just my observation and to give you a heads up on a potential problem.
                '79 MGB - LZ9 - T5
                  • 9190
                  I'd say call/email them and ask. But looking at the site, it looks like #6 might be your answer: http://www.jagsthatrun.com/Pages/Spe...integralsleeve
                  • cardana24
                    • 434
                    I sent an email yesterday, and I left a voice mail today.
                    • cardana24
                      • 434
                      anyone know how to get intouch with these guys? They have not answered the phone for 2 days.
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        Hopefully, someone here will be able to give you the answer since their website says "PLEASE NOTE: Our manual goes into greater detail on this topic! We regret that we are unable to enter into telephone or e-mail discussions concerning it, as we just cannot spare the time!".
                        Perhaps they would respond with their policy regarding returns and exchanges. They may let you buy one, try it and exchange it if it isn't the proper one.
                        In case you haven't seen it, here's a link to the VSS section of their manual. http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
                        '79 MGB - LZ9 - T5
                        • cardana24
                          • 434
                          I can't get intouch with them. I really want to get this taken care of. Any more advice on which one would work?
                          • cardana24
                            • 434
                            I may have found someone that can help me. I need to know if the signal is a Hall effect signal, an A/C (alternating current) siginal, or a D/C (Direct Current) signal.
                            From reading on the Stealth conversion/jags that run site, it it says that the camaros from 91-93 are A/C....well my engine came out of a 94 camaro.
                            Can someone please varify which signal I need. Thanks.
                              • 9190
                              A forum community dedicated to Chevy Impala SS owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, and more!
                              Scroll down to the last post. Might be an option for you...
